[GRASS-user] v.surf.rst limitations?
Michael Perdue
michael_perdue at yahoo.ca
Mon Dec 4 13:15:37 EST 2006
Hey Roberto,
Can you tell me more about this bug? I ran a tile through v.surf.bspline that was significantly larger than this and I never ran into any problems. Nor can I find any defects in the output.
GRASS 6.2.0 (Mudflats):~ > r.info map=BSP_FF
| Layer: BSP_FF Date: Sun Dec 3 18:53:28 2006 |
| Mapset: temp Login of Creator: maperdue |
| DataBase: /mnt/Storage1/grass |
| Title: ( BSP_FF ) |
| timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: DCELL |
| Rows: 6878 |
| Columns: 4798 |
| Total Cells: 33000644 |
| Projection: UTM (zone 10) |
| N: 5275187 S: 5268309 Res: 1 |
| E: 584612 W: 579814 Res: 1 |
| Range of data: min = 3.222074 max = 250.353352 |
| Data Source: |
| Data Description: |
| generated by v.surf.bspline |
This grid was 33mil cells with ~30mil input data points.
However, I do receive a seg fault when I try to define a set of sparce data nodes to be interolated (input_ext=).
Cheers,
Mike
PS Yes, v.surf.bspline is much faster than v.surf.rst. But more importantly, it seems to step through the data to prevent memory allocation errors. Is this true? Nice!!! :-)
Roberto Antolin <roberto.antolin at polimi.it> wrote: Hi Carlos and Mike,
At this moment, there is actually a limitation with v.surf.bspline.
There is a bug and I think it is no possible working with 13.5 mill
cells. I'm working on it, but by the moment It will reach only 4mill
cells. Yes, I know it is no enough, sorry. I hope that in a near future
this will be also fixed. Maybe, if you try with a lower resolution
(about 20m) v.surf.bspline should work.
However, I think v.surf.bspline will be faster than v.surf.rst. ;-)
Regards,
Roberto.
Michael Perdue ha scritto:
> Carlos,
> To the best of my knowledge, the only limitation on v.surf.rst is
> imposed by the limits of your hardware. IE, your probably running into
> memory allocation problems. You can try increasing your swap space,
> but be aware that v.surf.rst will take a painfully long time to
> process that many points. Alternately, I'd recommend you give r.in.xyz
> and v.surf.bspline a try.
> Cheers,
> Mike
> On 4-Dec-06, at 3:49 AM, Carlos "Guâno" Grohmann wrote:
>> Hello, I have this LIDAR dataset with abou 5.5 millions points that I
>> imported with v.in.ascii -ztb, and I want to interpolate in a DEM with
>> 5m resolution, which gives me about 13.5 million cells. When I try to
>> run v.surf.rst (GRASS 6.3 cvs), it get killed after 30-40 minutes. Is
>> there a limitation on v.surf.rst?
>> thanks
Roberto Antolín Sánchez
Politecnico di Milano Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
email: roberto.antolin at polimi.it
Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061204/76fdb139/attachment.html
