[GRASS-user] r.surf.nnbathy crashed [was: v.surf.rst limitations?]
    Maciej Sieczka
    tutey at o2.pl
    Tue Dec  5 15:35:12 EST 2006
Carlos "Guâno" Grohmann wrote:
> I compiled nnbathy with serial processing and imported the Lidar
> datase with r.in.xyz (which is very fast). Then I trye to interpolate
> with r.surf.nnbathy, but after about 30 minutes, it crashes with a msg
> like "Error in column 1 row 1"..
Hi Carlos,
Thanks for the feedback!
Propably nnbathy failed and r.in.ascii couldn't import it's output. I
should add error trapping in r.surf.nnbathy for such cases (I've got
several fixes and improvements waiting; propably will do on Christmas).
What: platform, compiler, nnbathy version?
Can I have a sample of your data crashing the nnbathy, along with your
region settings and the command syntax?
Can you add a following command into line 140 of the script:
cp $TMP.${PROG}.output_xyz $HOME/nnbathy_out_xyz
and send me the $HOME/nnbathy_out_xyz file?
Thanks,
Maciek
