[GRASS-user] db.connect!?
    Markus Neteler
    neteler at itc.it
    Sat Dec  9 00:56:37 EST 2006
if your host "debian" is localhost, try to use
"localhost" instead as host name.
if not or if fails, I guess that you have to enable
tcp for postmaster.
Markus
On Fri, Dec 08, 2006 at 03:27:21PM -0800, Salvator*eL*arosa wrote:
> Hi at all........
> I have a problem with db.connect module...
> I'm trying to connect to driver pg, the steps is following:
> db.connect driver=pg database=host=debian,dbname=mydb,port=5432
> db.login user=postgres pass=*******
> db.connect -p
> db.tables -p
> It get me error:
> GRASS 6.2.0 (ditragis):~ > db.connect -p
> driver:pg
> database:host=debian,dbname=ditragis_db,port=5432
> schema:public
> group:(null)
> GRASS 6.2.0 (ditragis):~ > db.tables -p
> DBMI-Postgres driver error:
> Cannot connect to Postgres: could not connect to server: Connection refused
>         Is the server running on host "debian" and accepting
>         TCP/IP connections on port 5432?
> I have set up my /etc/profile PATH to /usr/local/pgsql/bin.
> Can someone help me?
> View this message in context: http://www.nabble.com/db.connect%21--tf2783749.html#a7767245
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
