[GRASS-user] db.connect!?
Salvator*eL*arosa s_larosa at libero.it
Sat Dec 9 05:07:20 EST 2006
Thanks for your quick reply.
I have tried to replace localhost in debian, now work nice!
Markus Neteler wrote:
> Hi,
> if your host "debian" is localhost, try to use
> "localhost" instead as host name.
> if not or if fails, I guess that you have to enable
> tcp for postmaster.
> Markus
> On Fri, Dec 08, 2006 at 03:27:21PM -0800, Salvator*eL*arosa wrote:
>> Hi at all........
>> I have a problem with db.connect module...
>> I'm trying to connect to driver pg, the steps is following:
>> db.connect driver=pg database=host=debian,dbname=mydb,port=5432
>> db.login user=postgres pass=*******
>> db.connect -p
>> db.tables -p
>> It get me error:
>> GRASS 6.2.0 (ditragis):~ > db.connect -p
>> driver:pg
>> database:host=debian,dbname=ditragis_db,port=5432
>> schema:public
>> group:(null)
>> GRASS 6.2.0 (ditragis):~ > db.tables -p
>> DBMI-Postgres driver error:
>> Cannot connect to Postgres: could not connect to server: Connection
>> refused
>>         Is the server running on host "debian" and accepting
>>         TCP/IP connections on port 5432?
>> I have set up my /etc/profile PATH to /usr/local/pgsql/bin.
>> Can someone help me?
>> View this message in context:
>> http://www.nabble.com/db.connect%21--tf2783749.html#a7767245
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
View this message in context: http://www.nabble.com/db.connect%21--tf2783749.html#a7770863
