[GRASSLIST:10165] updates to gism2 - Feb 6, 2006
    Patton, Eric
    epatton at nrcan.gc.ca
    Mon Feb  6 08:43:32 EST 2006
Michael,
I tested your fixes out this morning, and encountered no problems - thanks!
I have a few ideas/comments/requests:
1) Would it be possible to be able to open .dm and .dmrc files in the gis
manager? I notice that gism complains about a dm file being a bad file
format. Alternatively, is there a simple hack that could be applied to a dm
file via a text edit to make it gism compatible? I've customized my dm file
for each location pretty extensively, I'm just trying to avoid having to
rebuild each one from scratch.
2) IMO, I think the panning/zooming tools ought to be 'sticky', as the old
dm tools were. Panning and zooming remains 'on' until the user signals they
are finished (right-click, as before ?). This would aviod the repetitive
back-and-forth clicking on the toolbar. As well, I think the help message
that displays on each zoom/pan tool click should only display once each
session (maybe include some kind of verbose flag in a setup file that could
kill the display of help messages?)
3) I noticed that resizes of the display canvas occasionally give an EOF
error - I can't reproduce it on every resize, but it comes and goes. I've
attached the log file. Also, if the display canvas is resized in height ( ~
100 pixels or more), the green background of the display canvas under the
display tools grows in proportion to the canvas height increase - minor
gripe.
4) And this item isn't a complaint! I like the addition of d.histogram,
d.rast.num, and d.rast.arrow tools to the main gism, especially d.histogram.
Anything that streamlines the use of any tool will mean they will get used
more in general, so thanks for that.
~ Eric.
-----Original Message-----
To: C. H. Roosevelt; Patton, Eric
Cc: 'grass developers list '; Multiple recipients of list
Sent: 2/3/2006 1:58 PM
Subject: Re: [GRASSLIST:10124] RE: updates to gism2 - Feb2, 2006
Chris and Eric,
I fixed these issues in the cvs and the copy on my website now.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
<http://www.public.asu.edu/~cmbarton>
  _____
Date: Thu, 2 Feb 2006 09:59:06 -0500
To: "Patton, Eric" <epatton at nrcan.gc.ca>
Cc: 'Michael Barton ' <michael.barton at asu.edu>,
"'owner-GRASSLIST at baylor.edu '" <owner-GRASSLIST at baylor.edu>, 'grass
developers list ' <grass5 at grass.itc.it>, 'Multiple recipients of list '
<GRASSLIST at baylor.edu>
Hi again,
Thank you again for the most recent fixes!
I can verify Eric's errors 1-3 regarding workspace resource files, again
working on MacOSX. The only notes I'd add include the following:
1) Clicking the 'Open existing workspace file' button opens a 'Save
File'
dialog box. Shouldn't this be an Open File box?
This seems only to be a dialog box *title* problem: the button does
actually open (and not save) a resource file.
2) Trying to open a Workspace file through File/Groups/Open menu gives
an
error. I've attached it as 'Open Workspace Error.log'.
3) I created a workspace file from scratch. I added 2 rasters to the gis
manager, then clicked File/Groups/Save as which gave the error message
attached in 'Save_Workspace_Error.log'. I am able to save the workspace
using the GUI button on the display manager, however. The saved
workspace
file re-opens normally.
While the GUI buttons related to resource files all work for me, the
only command under the menus (File>Groups> ...) that seems to work is
"Close". By the same token, the only keyboard shortcut that works in
this menu is ctrl-W for "Close."
Chris
On Feb 2, 2006, at 9:29 AM, Patton, Eric wrote:
Hi Michael,
I downloaded gism_rc1_20060201 this morning and gave it a try; thanks
for
the updates! We're definitely getting closer here.
Some observations:
File'
an
workspace
4) Most Grass commands typed into the run dialog don't seem to do
anything.
I only tried a few commands, i.e. g.region -p, d.rast map=rastername
don't
run, but r.composite does. Do only a subset of Grass programs run in
this
dialog?
5) Once a code block is pasted into the 'run' dialog, clicking the
'save'
button produces an error message, which is attached as
Command_Save_Error.log.
HTH,
~ Eric.
To: grass developers list; Multiple recipients of list
Sent: 2/1/2006 7:55 PM
Subject: [GRASSLIST:10120] updates to gism2
I posted to my web site and Markus helped me commit to the cvs a set of
updates to the GIS Manager 2 GUI that addresses some of the issues that
popped up over the last couple days.
I noticed that I cannot produce text overlays on my Mac using d.text or
d.text.freetype. I'd like to know if this is the same under other OS's
also. d.label does work, however.
d.text.freetype has not worked on the Mac since the upgrade to OSX10.4,
but d.text did work. So I need to know if this is a Mac issue or
everyone has the same lack of text under the new TclTk canvas displays.
If the latter, I can add a TclTk text module that will do essentially
the same thing as d.text.freetype and should work on all systems.
Michael
USA
<Open_Workspace_Error.log>
<Save_Workspace_Error.log>
<Command_Save_Error.log>
C. H. Roosevelt
Archaeology Department
Boston University
675 Commonwealth Avenue
Boston, MA, 02215-1406
Tel: (617) 358-1652 (direct)
Tel: (617) 353-3415 (main office)
Fax: (617) 353-6800
E-mail: chr at bu.edu
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060206/77b4980f/Monitor_Resize_Error.obj
