[GRASSLIST:10166] Re: Problems with r.proj - grass 6.01
Helmut Kudrnovsky hellik at web.de
Mon Feb 6 10:58:29 EST 2006
hi maciek, dear grassers,
i followed the steps proposed by Maciek.
for information about region and resolution settings i attached the v.info and r.info-output from the different steps.
everything seems to work, but not the last step with r.proj.
grass60 is creating a raster-map by r.proj.
this raster-map has the right region, but no content (see r.info below: Range of data:  min =  nan max = nan)
is there maybe a problem with the proj-library?
thanks in advance
greetings
helli
<Helmut,
<I gues your problem is that you need to set up the region in BOTH inout
<and output location so it covered the extent of raster data you need to
<reproject. This can be easily achieved like this:
<IN INPUT LOACTION
<1 set up the region
<2 v.in.region type=line output=the_region
v.info from step 2:
v.info map=cregion layer=1
 | Layer:    cregion                        Organization:                     |
 | Mapset:   imagedate                      Source Date:                      |
 | Location: salzburgepsg                   Name of creator:                  |
 | Database: //home/helli/grassdata                                           |
 | Title:        |
 | Map Scale:  1:1                                                            |
 | Map format: native                                                         |
 |   Type of Map:  Vector (level: 2)                                          |
 |   Number of points:       0               Number of areas:      0          |
 |   Number of lines:        1               Number of islands:    0          |
 |   Number of boundaries:   0               Number of faces:      0          |
 |   Number of centroids:    0               Number of kernels:    0          |
 |   Map is 3D:              0                                                |
 |   Number of dblinks:      0                                                |
 |   Projection: Transverse Mercator (zone 0)                                 |
 |            N: 5321295.600    S: 5318948.400                                |
 |            E: 4563992.800     W: 4561644.000                               |
 |            B: 0.000         T: 0.000                                       |
 |   Digitize threshold: 0.00000                                              |
 |   Comments:        |
r.info from the raster of the input-location:
r.info map=comp
 | Layer:    comp                           Date: Mon Feb  6 11:01:08 2006    |
 | Mapset:   imagedate                      Login of Creator: helli           |
 | Location: salzburgepsg                                                     |
 | DataBase: //home/helli/grassdata                                           |
 | Title:     ( comp )                                                        |
 |   Type of Map:  raster              Number of Categories: 32767            |
 |   Data Type:    CELL                                                       |
 |   Rows:         2347                                                       |
 |   Columns:      2349                                                       |
 |   Total Cells:  5513103                                                    |
 |            N:  5321295.6    S:  5318948.4   Res: 1.00008522                |
 |            E:  4563992.8    W:    4561644   Res: 0.99991486                |
 |   Range of data:    min =  0 max = 32767                                   |
 |   Data Source:                                                             |
 |   Data Description:                                                        |
 |    generated by r.composite                                                |
<IN OUTPUT LOCATION
<3 v.proj the "the_region" you created in step 2
<4 g.region vect=the_region
<5 r.proj
v.info from step 3
v.info map=cregionsbg layer=1
 | Layer:    cregionsbg                     Organization:                     |
 | Mapset:   images                         Source Date:                      |
 | Location: bayern                         Name of creator:                  |
 | Title:        |
 | Map Scale:  1:1                                                            |
 |   Map is 3D:              0                                                |
 |            N: 5355698.416    S: 5353360.038                                |
 |            E: 8608139.963     W: 8605864.833                               |
 |            B: 0.000         T: 0.000                                       |
 |   Comments:        |
r.info from the raster of the output-location:
r.info map=so00641compbay
 | Layer:    so00641compbay                 Date: Mon Feb  6 11:20:28 2006    |
 | Mapset:   images                         Login of Creator: helli           |
 | Location: bayern                                                           |
 | Title:     ( so00641compbay )                                              |
 |   Type of Map:  raster              Number of Categories: 255              |
 |   Data Type:    FCELL                                                      |
 |   Rows:         2340                                                       |
 |   Columns:      2276                                                       |
 |   Total Cells:  5325840                                                    |
 |            N: 5355698.98489831    S: 5353359.0418025   Res: 0.99997568     |
 |            E: 8608140.67246773    W: 8605864.66151311   Res: 1.00000481    |
 |   Range of data:    min =  nan max = nan                                   |
 |   Data Source:                                                             |
 |   Data Description:                                                        |
 |    generated by r.proj                                                     |
<Maciek>
GRASS 6.0.1 (2005)
Maciek Sieczka <werchowyna at epf.pl> schrieb am 03.02.06 17:57:19:
Helmut,
IN INPUT LOACTION
1 set up the region
IN OUTPUT LOCATION
5 r.proj
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
