[GRASSLIST:10218] RE: some nice results from r.sun
José A. Ruiz Arias
jararias at ujaen.es
Thu Feb 9 03:34:49 EST 2006
Dear Dylan,
You thought so well since for me it is so interesting to know the strength
of r.sun. I work at the University of Jaén on the solar radiation estimates
in mountainous terrain with very complex topography in Southern-Spain. There
exist some models to do it and, with no doubt, r.sun is a very good choice.
Now I am focusing on the resolution of the DEM and its influence on the
solar radiation estimate with Solar Analyst but my intentions are to move to
r.sun in a short time. For this reason your comments and results are "nice"
for me.
Greetings
José A. Ruiz Arias
Departamento de Física
Campus Lagunillas
Edificio A-3 Despacho 066
Universidad de Jaén
23071 Jaén España
Tlf. +34 953 212474
-----Mensaje original-----
De: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] En nombre
de Dylan Beaudette
Enviado el: jueves, 09 de febrero de 2006 4:07
Para: GRASSLIST at baylor.edu
Asunto: [GRASSLIST:10214] some nice results from r.sun
Just thought that I would share some nice results from r.sun.
Comparing the daily summed insolation values modeled by r.sun with 2 years
of
solar data from the exact same spot revealed a nice correlation between the
two:
http://169.237.35.250/~dylan/temp/print_me/2004_2005-comparison-linke.pdf
Note the Linke turbidity values: they empirically monthly averages- and were
key to tracking the actual insolation values so closely. Also, the default
Linke value of 3 used for the entire year tracked the variation in measured
values well, but overestimated the actual values.
Thanks to the authors of r.sun for a job well done!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
__________ Informacisn de NOD32 1.1400 (20060208) __________
Este mensaje ha sido analizado con NOD32 antivirus system
http://www.nod32.com
