[GRASSLIST:10245] Re: v.in.ascii quirk
Maciek Sieczka
werchowyna at epf.pl
Fri Feb 10 05:26:53 EST 2006
Stuart,
On Thu, 9 Feb 2006 19:36:39 -0500
Stuart Edwards <sedwards2 at cinci.rr.com> wrote:
<snip>
> Output from v.in.ascii executed using GRASS GUI --- no .dbf file was
> created, although the command appeared to have run correctly.
> v.in.ascii input=/Users/stu/Desktop/grasstest/fivepoints
> output=fivecorners format=point 'fs='\'' '\''' skip=1 \
> 'columns='\''x double, y double, z double'\''' x=1 y=2 z=3 cat=0 -z
Are you by any chance putting 'x double, y double, z double' in GUI?
You should't - put plain x double, y double, z double instead - no '
at the beginning and at the end. Despite of what the "hint" in the GUI
itself suggests. This is a known problem -
https://intevation.de/rt/webrt?serial_num=4024.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
