[GRASSLIST:10248] Re: v.in.ascii quirk
Stuart Edwards
sedwards2 at cinci.rr.com
Fri Feb 10 11:30:29 EST 2006
Yes, I did have the ' ' in place. However when I run the GUI without
them, the .dbf file still is not created.
v.in.ascii input=/Users/stu/Desktop/grasstest/fivepoints output=fp
format=point 'fs='\'' '\''' skip=1 'columns=x double, y double, z
double,' x=1 y=2 z=3 cat=0 -z
The GUI appears to have inserted ' ' around the whole phrase
starting at 'columns rather than just around 'x double, etc. I also
tried leaving the ' ' out of the field separator field with similar
results.
Stu
On Feb 10, 2006, at 5:26 AM, Maciek Sieczka wrote:
> Stuart,
> On Thu, 9 Feb 2006 19:36:39 -0500
> Stuart Edwards <sedwards2 at cinci.rr.com> wrote:
> <snip>
>> Output from v.in.ascii executed using GRASS GUI --- no .dbf file was
>> created, although the command appeared to have run correctly.
>> output=fivecorners format=point 'fs='\'' '\''' skip=1 \
>> 'columns='\''x double, y double, z double'\''' x=1 y=2 z=3 cat=0 -z
> Are you by any chance putting 'x double, y double, z double' in GUI?
> You should't - put plain x double, y double, z double instead - no '
> at the beginning and at the end. Despite of what the "hint" in the GUI
> itself suggests. This is a known problem -
> https://intevation.de/rt/webrt?serial_num=4024.
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie
> tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
