[GRASSLIST:10254] Re: gismlegend.txt problem
Ing.Peter Misovic peter.misovic at gmail.com
Fri Feb 10 18:14:30 EST 2006
yes, I had also old version of d.vect.thematic. I went through code
and didn'f find stage with .txt file creation.
Thank you for you support.
Peter
On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
> Peter,
> Something just occurred to me. For thematic mapping in the new GIS Manager
> to work, you must have an updated version of d.vect.thematic (released this
> week).
> This is in the CVS and available from my website. Did you install a new
> d.vect.thematic?
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > Date: Fri, 10 Feb 2006 23:18:39 +0100
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: Multiple recipients of list <GRASSLIST at baylor.edu>
> > Subject: Re: [GRASSLIST:10232] gismlegend.txt problem
> > Hi Michael again,
> > the problem is that d.vect.thematic is not creating this file anymore.
> > If I create this file by my own (in my default directory)
> > d.vect.thematic is not terminated abnormally. Even though that fact,
> > the file has Ob size and GIS Monitor displays nothing at all.
> > Thank you for you help,
> > Peter
> >> This problem may happen to other people.
> >> In order to make a legend in the new GIS Manager,  must
> >> create a text file containing legend parameters and give it a name that gism
> >> can recognize. So, I've had d.vect.thematic write these out to a file named
> >> gismlegend.txt in the user's default directory (usually the home directory).
> >> If you cannot write to your default directory--whatever it
> >> is--gismlegend.txt won't get written and the GIS Manager won't find it.
> >> See if you are getting this file written into your default directory. If
> >> not, try making sure the permissions are set to let you write in the
> >> directory.
> >> Michael
> >> __________________________________________
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >>> Date: Thu, 9 Feb 2006 23:35:42 +0100
> >>> To: grass list <GRASSLIST at baylor.edu>
> >>> Subject: [GRASSLIST:10232] gismlegend.txt problem
> >>> Dear all,
> >>> I have problem in GM2 during following process:
> >>> a.) open d.vect.thematic
> >>> b.) setting of all related parameters
> >>> c.) switch to grass monitor
> >>> d.) click on redraw icon (top-left)
> >>> d.) error occuring : couldn't open "gismlegend.txt": no such file or
> >>> directory
> >>> Thank you,
> >>> Peter
