[GRASSLIST:10253] Re: gismlegend.txt problem
    Ing.Peter Misovic
    peter.misovic at gmail.com
    Fri Feb 10 18:11:32 EST 2006
Hi again ;)
the problem was soleved by following way (maybe it can help somebody):
a.) Download thematic.tgz from
http://www.public.asu.edu/~cmbarton/files/grass_scripts/
b.) copy d.vect.thematic and v.univar.sh into (grass dir/scripts)
c.) manually create gismlegend.txt in you default directory
My fault was that I did not copy v.univar.sh into scripts folder.
This is how I installed v.what. Maybe, it could help somebody.
a.) download gism_rc2_20060206.tgz from
http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr/ - package
contains new Gis Manager and new v.what script. First of all, create
folder v.what in (unTARed folder with grass sources)/vector/ and copy
all files from v.what/source/v.what.tar.gz into this new folder.
b.) run ./configure as you need, then make (as normal user)
c.) go into vector/v.what folder and run make
d.) do #make install (as root)
Peter
On 2/10/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> Hi Michael again,
> the problem is that d.vect.thematic is not creating this file anymore.
> If I create this file by my own (in my default directory)
> d.vect.thematic is not terminated abnormally. Even though that fact,
> the file has Ob size and GIS Monitor displays nothing at all.
> Thank you for you help,
> Peter
> On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
> > This problem may happen to other people.
> > In order to make a legend in the new GIS Manager,  must
> > create a text file containing legend parameters and give it a name that gism
> > can recognize. So, I've had d.vect.thematic write these out to a file named
> > gismlegend.txt in the user's default directory (usually the home directory).
> > If you cannot write to your default directory--whatever it
> > is--gismlegend.txt won't get written and the GIS Manager won't find it.
> > See if you are getting this file written into your default directory. If
> > not, try making sure the permissions are set to let you write in the
> > directory.
> > Michael
> > __________________________________________
> > Michael Barton, Professor of Anthropology
> > School of Human Evolution and Social Change
> > Arizona State University
> > Tempe, AZ 85287-2402
> > phone: 480-965-6213
> > fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> > > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > > Date: Thu, 9 Feb 2006 23:35:42 +0100
> > > To: grass list <GRASSLIST at baylor.edu>
> > > Subject: [GRASSLIST:10232] gismlegend.txt problem
> > > Dear all,
> > > I have problem in GM2 during following process:
> > > a.) open d.vect.thematic
> > > b.) setting of all related parameters
> > > c.) switch to grass monitor
> > > d.) click on redraw icon (top-left)
> > > d.) error occuring : couldn't open "gismlegend.txt": no such file or directory
> > > Thank you,
> > > Peter
