[GRASSLIST:10258] Re: gismlegend.txt problem
Ing.Peter Misovic peter.misovic at gmail.com
Fri Feb 10 19:27:27 EST 2006
I'm already done with CVS installation. Everything seems to be ok
except one thing. I've attached error snapshot (I was clicled on
thematic group and if I clicked for info in Monitor)
Peter
On 2/11/06, Michael Barton <michael.barton at asu.edu> wrote:
> You should already have v.univar.sh in a normal GRASS distribution. However,
> it looks like you needed the new d.vect.thematic.
> You are also correct that you need to install v.what if you want to do
> vector querying.
> These steps are listed in the README file that accompanies the version of
> the GIS Manager that comes from my web site. All the appropriate files
> should also be in the cvs.
> Let me know if they are not.
> Glad it is working.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > Date: Sat, 11 Feb 2006 00:11:32 +0100
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: Multiple recipients of list <GRASSLIST at baylor.edu>
> > Subject: Re: [GRASSLIST:10232] gismlegend.txt problem
> > Hi again ;)
> > the problem was soleved by following way (maybe it can help somebody):
> > a.) Download thematic.tgz from
> > http://www.public.asu.edu/~cmbarton/files/grass_scripts/
> > b.) copy d.vect.thematic and v.univar.sh into (grass dir/scripts)
> > c.) manually create gismlegend.txt in you default directory
> > My fault was that I did not copy v.univar.sh into scripts folder.
> > This is how I installed v.what. Maybe, it could help somebody.
> > a.) download gism_rc2_20060206.tgz from
> > http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr/ - package
> > contains new Gis Manager and new v.what script. First of all, create
> > folder v.what in (unTARed folder with grass sources)/vector/ and copy
> > all files from v.what/source/v.what.tar.gz into this new folder.
> > b.) run ./configure as you need, then make (as normal user)
> > c.) go into vector/v.what folder and run make
> > d.) do #make install (as root)
> > Peter
> > On 2/10/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> >> Hi Michael again,
> >> the problem is that d.vect.thematic is not creating this file anymore.
> >> If I create this file by my own (in my default directory)
> >> d.vect.thematic is not terminated abnormally. Even though that fact,
> >> the file has Ob size and GIS Monitor displays nothing at all.
> >> Thank you for you help,
> >> Peter
> >> On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
> >>> This problem may happen to other people.
> >>> In order to make a legend in the new GIS Manager,  must
> >>> create a text file containing legend parameters and give it a name that gism
> >>> can recognize. So, I've had d.vect.thematic write these out to a file named
> >>> gismlegend.txt in the user's default directory (usually the home directory).
> >>> If you cannot write to your default directory--whatever it
> >>> is--gismlegend.txt won't get written and the GIS Manager won't find it.
> >>> See if you are getting this file written into your default directory. If
> >>> not, try making sure the permissions are set to let you write in the
> >>> directory.
> >>> Michael
> >>> __________________________________________
> >>> phone: 480-965-6213
> >>> fax: 480-965-7671
> >>>> Date: Thu, 9 Feb 2006 23:35:42 +0100
> >>>> To: grass list <GRASSLIST at baylor.edu>
> >>>> Subject: [GRASSLIST:10232] gismlegend.txt problem
> >>>> Dear all,
> >>>> I have problem in GM2 during following process:
> >>>> a.) open d.vect.thematic
> >>>> b.) setting of all related parameters
> >>>> c.) switch to grass monitor
> >>>> d.) click on redraw icon (top-left)
> >>>> d.) error occuring : couldn't open "gismlegend.txt": no such file or
> >>>> directory
> >>>> Thank you,
> >>>> Peter
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060211/1a62b028/snapshot1.png
