[GRASSLIST:10262] Re: gismlegend.txt problem
Ing.Peter Misovic peter.misovic at gmail.com
Sat Feb 11 07:49:11 EST 2006
Hi Michael,
we have found some issue with v.what in Map Display window (new GM).
What is the problem ? I don't know, how the SQL WHERE STATMETS works,
but I think, It's just setting backgroud color to don't matching
records. And because of v.what script is based on coordinates imput it
returns records info even if I apply sql statment (because as I said,
maybe it only changes color of element). In other words, If I apply
sql statment and after that I click for info in Map Display it will
return information for nonvisible elements.
Would you be so kind to help me with that issue ? I hope, I've
described it in understable way.
Peter
On 2/11/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> Hi,
> I'm already done with CVS installation. Everything seems to be ok
> except one thing. I've attached error snapshot (I was clicled on
> thematic group and if I clicked for info in Monitor)
> Peter
> On 2/11/06, Michael Barton <michael.barton at asu.edu> wrote:
> > You should already have v.univar.sh in a normal GRASS distribution. However,
> > it looks like you needed the new d.vect.thematic.
> > You are also correct that you need to install v.what if you want to do
> > vector querying.
> > These steps are listed in the README file that accompanies the version of
> > the GIS Manager that comes from my web site. All the appropriate files
> > should also be in the cvs.
> > Let me know if they are not.
> > Glad it is working.
> > Michael
> > ______________________________
> > Michael Barton, Professor of Anthropology
> > School of Human Evolution and Social Change
> > Arizona State University
> > Tempe, AZ  85287-2402
> > USA
> > voice: 480-965-6262; fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> > > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > > Date: Sat, 11 Feb 2006 00:11:32 +0100
> > > To: Michael Barton <michael.barton at asu.edu>
> > > Cc: Multiple recipients of list <GRASSLIST at baylor.edu>
> > > Subject: Re: [GRASSLIST:10232] gismlegend.txt problem
> > > Hi again ;)
> > > the problem was soleved by following way (maybe it can help somebody):
> > > a.) Download thematic.tgz from
> > > http://www.public.asu.edu/~cmbarton/files/grass_scripts/
> > > b.) copy d.vect.thematic and v.univar.sh into (grass dir/scripts)
> > > c.) manually create gismlegend.txt in you default directory
> > > My fault was that I did not copy v.univar.sh into scripts folder.
> > > This is how I installed v.what. Maybe, it could help somebody.
> > > a.) download gism_rc2_20060206.tgz from
> > > http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr/ - package
> > > contains new Gis Manager and new v.what script. First of all, create
> > > folder v.what in (unTARed folder with grass sources)/vector/ and copy
> > > all files from v.what/source/v.what.tar.gz into this new folder.
> > > b.) run ./configure as you need, then make (as normal user)
> > > c.) go into vector/v.what folder and run make
> > > d.) do #make install (as root)
> > > Peter
> > > On 2/10/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> > >> Hi Michael again,
> > >> the problem is that d.vect.thematic is not creating this file anymore.
> > >> If I create this file by my own (in my default directory)
> > >> d.vect.thematic is not terminated abnormally. Even though that fact,
> > >> the file has Ob size and GIS Monitor displays nothing at all.
> > >> Thank you for you help,
> > >> Peter
> > >> On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
> > >>> This problem may happen to other people.
> > >>> In order to make a legend in the new GIS Manager,  must
> > >>> create a text file containing legend parameters and give it a name that gism
> > >>> can recognize. So, I've had d.vect.thematic write these out to a file named
> > >>> gismlegend.txt in the user's default directory (usually the home directory).
> > >>> If you cannot write to your default directory--whatever it
> > >>> is--gismlegend.txt won't get written and the GIS Manager won't find it.
> > >>> See if you are getting this file written into your default directory. If
> > >>> not, try making sure the permissions are set to let you write in the
> > >>> directory.
> > >>> Michael
> > >>> __________________________________________
> > >>> phone: 480-965-6213
> > >>> fax: 480-965-7671
> > >>>> Date: Thu, 9 Feb 2006 23:35:42 +0100
> > >>>> To: grass list <GRASSLIST at baylor.edu>
> > >>>> Subject: [GRASSLIST:10232] gismlegend.txt problem
> > >>>> Dear all,
> > >>>> I have problem in GM2 during following process:
> > >>>> a.) open d.vect.thematic
> > >>>> b.) setting of all related parameters
> > >>>> c.) switch to grass monitor
> > >>>> d.) click on redraw icon (top-left)
> > >>>> d.) error occuring : couldn't open "gismlegend.txt": no such file or
> > >>>> directory
> > >>>> Thank you,
> > >>>> Peter
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060211/3624dfdd/snapshot2.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060211/3624dfdd/snapshot3.png
