[GRASSLIST:10320] Re: robinson (winkel) projection
Ian MacMillan
Ian.MacMillan at pomona.edu
Wed Feb 15 13:29:54 EST 2006
Otto, I have made some robinson locations for my work, and the process
is pretty straight forward. After selecting 'create new location' when
first opening grass, select that you would like to use 'Other
Projection' when asked for your coord. system. When asked to specify
your projection name, just use 'robin'. Select your datum as usual.
You will then have to input your central parallel, central meridian,
and preferred units. For most robinson projections that you see in
atlases, the central parallel is the equator (0), and the central
meridian is the Greenwich meridian (also 0). I usually use meters as
my preferred units.
Degrees would be really nice as a standard unit for these kinds of
projections, but since their absolute length varies depending on your
location on the earth, they can't be used in grass. My workaround to
this has been to make a vector grid in a latlong location that is
spaced about ten or fifteen degrees apart for the entire earth. I then
project (with v.proj) that vector file into my robinson location as a
first step so that I can see where I am in the world.
Once you are done with all of that, use r.proj and v.proj at your
leisure in your new location.
Hope this helps,
Ian
On Feb 15, 2006, at 4:25 AM, Otto Dassau wrote:
> Hi,
> I would like to convert a lat/lon map into a robinson (winkel)
> projection.
> does anybody has experience with the creation of a robinson (winkel)
> projektion in GRASS? It seems to be supported (robin, winkel,...) but I
> haven't found out, how to create a robin location in GRASS and which
> parameters a normaly used.
> thanks
> Otto
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
- Dave Barry
This message has been scanned by Postini anti-virus software.
