[GRASSLIST:10323] Re: robinson (winkel) projection
William Kyngesburye
woklist at kyngchaos.com
Wed Feb 15 14:00:17 EST 2006
One important thing I found - use a sphere, not an ellipsoid. If you
use an ellipsoid, there will be an approx. 20000m N-S shift at around
45 deg N and S (for the Robinson, at least), which is quite noticable
at any scale. I agonized over this for a while, using WGS84
ellipsoid out of habit, and even thought it was a bug, until I
figured out the cause. -> use a sphere for global projections.
On Feb 15, 2006, at 12:29 PM, Ian MacMillan wrote:
> Otto, I have made some robinson locations for my work, and the
> process is pretty straight forward. After selecting 'create new
> location' when first opening grass, select that you would like to
> use 'Other Projection' when asked for your coord. system. When
> asked to specify your projection name, just use 'robin'. Select
> your datum as usual. You will then have to input your central
> parallel, central meridian, and preferred units. For most robinson
> projections that you see in atlases, the central parallel is the
> equator (0), and the central meridian is the Greenwich meridian
> (also 0). I usually use meters as my preferred units.
> Degrees would be really nice as a standard unit for these kinds of
> projections, but since their absolute length varies depending on
> your location on the earth, they can't be used in grass. My
> workaround to this has been to make a vector grid in a latlong
> location that is spaced about ten or fifteen degrees apart for the
> entire earth. I then project (with v.proj) that vector file into
> my robinson location as a first step so that I can see where I am
> in the world.
> Once you are done with all of that, use r.proj and v.proj at your
> leisure in your new location.
> Hope this helps,
> Ian
> On Feb 15, 2006, at 4:25 AM, Otto Dassau wrote:
>> Hi,
>> I would like to convert a lat/lon map into a robinson (winkel)
>> projection.
>> does anybody has experience with the creation of a robinson (winkel)
>> projektion in GRASS? It seems to be supported (robin, winkel,...)
>> but I
>> haven't found out, how to create a robin location in GRASS and which
>> parameters a normaly used.
>> thanks
>> Otto
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
