[GRASSLIST:10361] Re: Regarding Grass
RAVI KUMAR
ravivundavalli at yahoo.com
Fri Feb 17 03:37:20 EST 2006
If U R a 1st time user then download latest CSV from website and follow instructions on the page.
We have used on PcqLinux-2005.
while loading the list of RPMs
Use --force where ever U get a message of failure to load RPM
Here is how I installed GRASS6.0
U must also have spearfish data to try out after successful installation
I have some Hyderabad dataset made using google images.
and a paper too. Total size around 4mb. Pl let me know if U are interested.
Good to note some Indians on this list.
Ravi Kumar
Steps for GRASS installation
JUST CUT AND PASTE EACH STEP IN A TERMINAL WINDOW.
U MUST LOG IN AS A ROOT OR SUPER USER
TYPE
su <ent>
password <ent> 'ENTER YOUR ROOT PASSWORD
STEP-1
(type/copy&paste the command below in one line on terminal window)
sh grass-6.0.0-i686-pc-linux-gnu-03_08_2005-install.sh grass-6.0.0-i686-pc-linux-gnu-03_08_2005.tar.gz
(# use --force option whenever there is a conflict with existing version of rpm
#example: rpm --install --force tk-8.3.3-74asp.i386.rpm --nodeps)
Step-2 installation of the rpms
rpm --install tk-8.3.3-74asp.i386.rpm --nodeps
rpm --install tcl-8.3.3-74.i386.rpm
rpm --install libproj0-4.4.8-1mdk.i586.rpm
rpm --install xterm-196-1mdk.i586.rpm
rpm --install libgrass5_0-1.0.0-1mdk.i586.rpm
rpm --install libgdal0-1.1.9-2mdk.i586.rpm
rpm --install libgdal1-1.2.2-1mdk.i586.rpm --nodeps
rpm --install libfftw2-2.1.5-3mdk.i586.rpm
rpm --install libjasper1.701_1-1.701.0-1mdk.i686.rpm
rpm --install libogdi-3.1.2-1mdk.i586.rpm
rpm --install libgeotiff1-1.2.2-2mdk.i586.rpm
rpm --install libstdc++6-3.4.1-4mdk.i586.rpm
STEP-3
ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0
ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0
ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2
ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1
ln -s /usr/lib/libfftw.so.2 /usr/lib/libdfftw.so.2
ldconfig
STEP-4
TYPE
exit <ent> ' to log off as super user
STEP-5
right click on
spearfish_grass57data.tar file --> extract
TYPE
grass60 <ent> ' to start grass'
if it does not start type /usr/local/bin/grass60
use spearfish57 as data, for acquainting.
GOOD LUCK
sharada kaisuvker <sharadakaisuvker at yahoo.co.in> wrote:
sir,
we have installed GRASS binaries. We are using Fedora core3 platform.Should we now install tcltk if yes then please suggest the version.
Also we would like to know whether to install source code and then compile it or can we complete our project using GRASS binaries only.
Please reply immediately.
Awaiting for response.
Thanking You
Jiyo cricket on Yahoo! India cricket
Yahoo! Messenger Mobile Stay in touch with your buddies all the time.
Yahoo! Autos. Looking for a sweet ride? Get pricing, reviews, & more on new and used cars.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060217/6170e193/attachment.html
