[GRASSLIST:10363] Re: Regarding Grass
Buchan Milne
bgmilne at mandriva.org
Fri Feb 17 05:06:28 EST 2006
On Friday 17 February 2006 10:37, RAVI KUMAR wrote:
> Hi,
> If U R a 1st time user then download latest CSV from website and follow
> instructions on the page. We have used on PcqLinux-2005.
> while loading the list of RPMs
> Use --force where ever U get a message of failure to load RPM
^^^^^^^ This is really bad advice.
> Here is how I installed GRASS6.0
> U must also have spearfish data to try out after successful installation
> I have some Hyderabad dataset made using google images.
> and a paper too. Total size around 4mb. Pl let me know if U are
> interested. Good to note some Indians on this list.
> Ravi Kumar
> Steps for GRASS installation
> JUST CUT AND PASTE EACH STEP IN A TERMINAL WINDOW.
> U MUST LOG IN AS A ROOT OR SUPER USER
> TYPE
> su <ent>
> password <ent> 'ENTER YOUR ROOT PASSWORD
> STEP-1
> (type/copy&paste the command below in one line on terminal window)
> sh grass-6.0.0-i686-pc-linux-gnu-03_08_2005-install.sh
> grass-6.0.0-i686-pc-linux-gnu-03_08_2005.tar.gz
> (# use --force option whenever there is a conflict with existing version of
> rpm #example: rpm --install --force tk-8.3.3-74asp.i386.rpm --nodeps)
> Step-2 installation of the rpms
> rpm --install tk-8.3.3-74asp.i386.rpm --nodeps
> rpm --install tcl-8.3.3-74.i386.rpm
> rpm --install libproj0-4.4.8-1mdk.i586.rpm
> rpm --install xterm-196-1mdk.i586.rpm
> rpm --install libgrass5_0-1.0.0-1mdk.i586.rpm
> rpm --install libgdal0-1.1.9-2mdk.i586.rpm
> rpm --install libgdal1-1.2.2-1mdk.i586.rpm --nodeps
> rpm --install libfftw2-2.1.5-3mdk.i586.rpm
> rpm --install libjasper1.701_1-1.701.0-1mdk.i686.rpm
> rpm --install libogdi-3.1.2-1mdk.i586.rpm
> rpm --install libgeotiff1-1.2.2-2mdk.i586.rpm
> rpm --install libstdc++6-3.4.1-4mdk.i586.rpm
If you're going to use so many Mandriva packages, why not just install
Mandriva 2006.0, visit http://urpmi-addmedia.org (or, add the contrib medium
from your local mirror), and:
# urpmi grass
(or, search for grass in the package management tools in Mandriva Control
Center)
Buchan Milne
B.Eng,RHCE(803004789010797),LPIC-2(LPI000074592)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060217/4ac481d2/attachment.bin
