[GRASSLIST:10439] Re: error writing cell file during copy
    Glynn Clements
    glynn at gclements.plus.com
    Mon Feb 20 12:15:30 EST 2006
Rochelle MIranda wrote:
> > >  I was looking into the source code when i came across the following module.
> > >  d.rast.edit
> > >  In file mk_new_layer.c
> > > What does the following if  expression mean:
> > >         if ( read (tmpfd, rast, real_ncols * cellsize) != (real_ncols * cellsize))
> > >             error(1,"error writing cell file during copy");
> > >  And when can such error occur what are its causes?.
> > The error will occur if the file wasn't written correctly, or has been
> > truncated or corrupted in the meantime.
> Sir , if am getting such an error , is there something i can do get
> rid of such error?
> Is it in our hands to overcome such errors which occur over
> meantime.
> Is there a way so tht the file will be written correctly and also
> to avoid the file gettting truncated or corrupted.what are the
> reasons for such file corruption to occur.
How large is the raster?
Unless it's particularly large (more than 2Gb uncompressed), any error
would probably be either a faulty hard disk (in which case, the kernel
should be reporting errors), or a bug in the program.
Can you identify a test case which would allow us to easily reproduce
the problem?
