[GRASSLIST:10508] Re: v.in.ascii in 6.1cvs
Nick Cahill
ndcahill at facstaff.wisc.edu
Wed Feb 22 01:29:00 EST 2006
I have had similar problems with the simplest imports of point data,
and ended up importing the data into postgres, then using v.in.db to
get it into GRASS. But this should work from v.in.ascii.
Nick Cahill
On Feb 21, 2006, at 11:07 PM, Ian MacMillan wrote:
> Hi all, I keep running into this problem, and would like to know if
> anyone else has had it. I am trying to import some point data
> using v.in.ascii with 6.1cvs. I have given a subset of the data here:
> -106.2222|46.6886
> -84.7156|10.4611
> -70.1978|47.2425
> -70.0064|47.4706
> -69.6897|47.7036
> -70.4125|47.4567
> -70.09|47.6931
> -69.8922|47.8264
> -174.2036|52.2117
> I have tried to import it into a lat-long location with:
> v.in.ascii input=test.txt output=test
> and get this error:
> *** malloc[25099]: Deallocation of a pointer not malloced:
> 0x1108ab0; This could be a double free(), or free() called with the
> middle of an allocated block; Try setting environment variable
> MallocHelp to see tools to help debug
> Segmentation fault
> Why can't I get this really simple operation to work? I have tried
> adding parameters like:
> v.in.ascii input=test.txt output=test x=1 y=2 z=0 fs='|' -zbt
> with no luck. I end up getting an error stating that I should
> define a 'reasonable' value for z. Omitting the 'z=' yields an
> error asking for the z column. If I omit the '-zbt' I end up with
> the same malloc error.
> This has routinely been an error for me since at least October in
> the cvs branch. I have installed the newest version from Lorenzo's
> site, with the new libraries.
> Sorry to be a pest with this problem (my third time writing about
> it), but I'd like to get this basic functionality back.
> Thanks,
> Ian
> This message has been scanned by Postini anti-virus software.
