[GRASSLIST:10517] Re: v.in.ascii in 6.1cvs
Thomas Adams
Thomas.Adams at noaa.gov
Wed Feb 22 07:26:58 EST 2006
Ian,
I don't have an answer for you, but using Lorenzo Moretti's GRASS 6.1cvs
(binary distribution) version for Mac OS X, I get the same error as you
do. I tried doing many different things to get it to work for several
hours with no avail. However, on a Linux machine which I built from the
GRASS 6.1cvs source dated 21 January 2006, I have no such problem.
So, there is a problem somewhere; unfortunately it seems to be like
tracking down an electrical short…
Regards,
Tom
Ian MacMillan wrote:
> Hi all, I keep running into this problem, and would like to know if
> anyone else has had it. I am trying to import some point data using
> v.in.ascii with 6.1cvs. I have given a subset of the data here:
> -106.2222|46.6886
> -84.7156|10.4611
> -70.1978|47.2425
> -70.0064|47.4706
> -69.6897|47.7036
> -70.4125|47.4567
> -70.09|47.6931
> -69.8922|47.8264
> -174.2036|52.2117
> I have tried to import it into a lat-long location with:
> v.in.ascii input=test.txt output=test
> and get this error:
> *** malloc[25099]: Deallocation of a pointer not malloced: 0x1108ab0;
> This could be a double free(), or free() called with the middle of an
> allocated block; Try setting environment variable MallocHelp to see
> tools to help debug
> Segmentation fault
> Why can't I get this really simple operation to work? I have tried
> adding parameters like:
> v.in.ascii input=test.txt output=test x=1 y=2 z=0 fs='|' -zbt
> with no luck. I end up getting an error stating that I should define a
> 'reasonable' value for z. Omitting the 'z=' yields an error asking for
> the z column. If I omit the '-zbt' I end up with the same malloc error.
> This has routinely been an error for me since at least October in the
> cvs branch. I have installed the newest version from Lorenzo's site,
> with the new libraries.
> Sorry to be a pest with this problem (my third time writing about it),
> but I'd like to get this basic functionality back.
> Thanks,
> Ian
> This message has been scanned by Postini anti-virus software.
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
