[GRASSLIST:10531] Re:
Michael Barton
michael.barton at asu.edu
Thu Feb 23 01:32:44 EST 2006
In the new GIS Manager, the display data button will now *display* data for
whatever layer you specify in the vector panel. Unfortunately, it still will
not let you *edit* the data.
Note: if there is some industrious person out there that really wants a data
editor and the undying gratitude of the GRASS user community, it should be
possible to write one using existing GRASS db.* commands and TclTk. There
are also some TclTk libraries--not currently required for GRASS--that
support table creation and management (tablelist) and SQLite.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: "Kirk R. Wythers" <kwythers at umn.edu>
> Date: Wed, 22 Feb 2006 08:32:02 -0600
> To: <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:10520]
> Is there a way to specify the layer (table) that comes up to
> interactively edit attributes in d.what.vect? In my case I have 2
> layers (ie tables) associated with a particular vector map. If I
> display the vector map with d.vect 'map_name' then run d.what.vect -e,
> the form that comes up only has the first layer (table) in it. I
> would like to edit layer 2, by clicking on the polygon in the vector
> map.
> Is that possible?
> Thanks,
> Kirk
