[GRASSLIST:10546] Re:
Radim Blazek
radim.blazek at gmail.com
Fri Feb 24 04:31:22 EST 2006
On 2/22/06, Kirk R. Wythers <kwythers at umn.edu> wrote:
> Is there a way to specify the layer (table) that comes up to
> interactively edit attributes in d.what.vect? In my case I have 2
> layers (ie tables) associated with a particular vector map. If I
> display the vector map with d.vect 'map_name' then run d.what.vect -e,
> the form that comes up only has the first layer (table) in it. I
> would like to edit layer 2, by clicking on the polygon in the vector
> map.
> Is that possible?
If you have 2 layers they should appear in 2 attribute tabs.
I guess that you dont have categories of the second layer assigned to
features in the map.
v.category option=report?
Radim
> Thanks,
> Kirk
