[GRASSLIST:10570] Re: r3.out.v5d
andrea.iescheck at ufpr.br
Sat Feb 25 14:14:36 EST 2006
Maciek,
When I select the icon r3.out.v5d it opens the command box where I select
the input grid3d file, type the output file name and run ... There is a
ligth showing the status of the command but it doesn´t completely ends and
there is no error messages. Anyway the output file is created, but when I
try to import it using vis5d the program (vis5d) prompts an error:
Making ap ...
Writing a 4.3 file!
S: lowlev=0 nl=30
Error in v5dCreateFile: open failed
Actually I´m not sure if there is a problem with the exported file or with
vis5d program!!
Thanks for your help
Andrea
> On Fri, 24 Feb 2006 16:48:15 -0300 (BRST)
> andrea.iescheck at ufpr.br wrote:
>> Hi,
>> I exported my grid3d data to vis5d but an error is reported when I
>> try to import the generated v5d file in vis5d.
>> It seems that the command r3.out.v5d is interrupted before the end,
>> but the v5d file is created!
> Post exact command syntax and output, including error. I'm not saying I
> will be able to help you but in order for anyone to be able to you must
> be specific.
>> I´ve installed grass 6.0.0 GNU.
> Cheers,
> Maciek
> W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko
> najlepsze z nich!
> http://katalog.panoramainternetu.pl/
