[GRASSLIST:10596] Re: OT : grass+postgis general question
    Ing.Peter Misovic
    peter.misovic at gmail.com
    Sun Feb 26 16:06:19 EST 2006
Ok thank you for your information.
My original idea (or what I like to see working :)) was that Grass
could read data directly from Postgres/PostGIS database and react on
database change. Or could it be done through OGR ? Or. I'm just
aksing.
Thank you,
Peter
>On 2/26/06, Laurent Courty <lrntct at gmail.com> wrote:
> Ing.Peter Misovic wrote:
> > Dear all,
> > is PostGIS as is supported by GRASS ? Is it possible to import table
> > with PostGIS column into Grass ? I've had some problem (the_geom is
> > not supported etc.). If not, exists some plans to do that ?
> > Thank you,
> > Peter
> Hello,
> OGR support postgis, so I think it's possible to import and export with
> v.in.ogr and v.out.ogr.
> Laurent
