[GRASSLIST:10602] Re: problems with GIS managerRe: GRASS 6.1cvs gis.m error
Michael Barton
michael.barton at asu.edu
Mon Feb 27 01:45:05 EST 2006
This monitorcap file does not belong with the version of GRASS you say you
downloaded ( grass6.1.cvs-i686-pc-linux-gnu-25_02_2006). It should look
different.
This makes me think that there is some kind of problem with your source
download or another issue with mixed versions and files.
I suggest you do a completely clean download of GRASS and a make clean
before you compile.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Mon, 27 Feb 2006 11:02:16 +0530
To: Michael Barton <michael.barton at asu.edu>
Cc: "Ing.Peter Misovic" <peter.misovic at gmail.com>, Multiple recipients of
list <GRASSLIST at baylor.edu>
Subject: Re: problems with GIS managerRe: GRASS 6.1cvs gis.m error
Hi Mike,
After entering grass, i saw that The grassrc6 file did have "MONITOR: X1" -
which i deleted. I also checked the monitorcap file, which did not have
duplicates.
I'm still getting the same errors. copied below is the monitorcap file:
any other suggestions? thanks much for your reply..- vishal
# Monitorcap file: describes the monitors available to your
# users. Fields:
# driver name :
# actual program name :
# short description presented to users :
# the names of two fifo files for interprocess communication :
# full pathname of tty from which device must be started (if any) :
# message user gets if driver is started from wrong tty
x0:driver/XDRIVER:X-windows graphics display: \
dev/fifo.1a dev/fifo.1b \
::any terminal
x1:driver/XDRIVER:X-windows graphics display: \
dev/fifo.2a dev/fifo.2b \
::any terminal
x2:driver/XDRIVER:X-windows graphics display: \
dev/fifo.3a dev/fifo.3b \
::any terminal
x3:driver/XDRIVER:X-windows graphics display: \
dev/fifo.4a dev/fifo.4b \
::any terminal
x4:driver/XDRIVER:X-windows graphics display: \
dev/fifo.5a dev/fifo.5b \
::any terminal
x5:driver/XDRIVER:X-windows graphics display: \
dev/fifo.6a dev/fifo.6b \
::any terminal
x6:driver/XDRIVER:X-windows graphics display: \
dev/fifo.7a dev/fifo.7b \
::any terminal
CELL:driver/CELL:Create GRASS Raster File: \
dev/fifo.8a dev/fifo.8b \
::any terminal
#sunview:driver/SUNVIEW:Sun graphics display: \
# dev/fifo.9a dev/fifo.9b \
# ::any terminal
#4105:driver/4105:Tektronix 4105: \
# dev/fifo.10a dev/fifo.10b \
# ::any terminal
#iris:driver/IRIS:Silicon Graphics IRIS Workstation: \
# dev/fifo.11a dev/fifo.11b \
# ::any terminal
#sun:driver/SUNCORE:Sun Core graphis display: \
# dev/fifo.12a dev/fifo.12b \
# ::any terminal
#IGRAPH:driver/IGRAPH:Intergraph graphics display: \
# dev/fifo.13a dev/fifo.13b \
# ::any terminal
#mass:driver/MASS:Masscomp graphics display: \
# dev/fifo.14a dev/fifo.14b \
# ::any terminal
PNG:driver/PNG:Create PNG Map: \
dev/fifo.16a dev/fifo.16b \
::any terminal
On 2/26/06, Michael Barton <michael.barton at asu.edu> wrote:
> Vishal,
> This is a different issue from what Peter reported. It sounds like there is a
> problem with your installation. I'd start by looking at the .grassrc6 file in
> your home directory. If there is a line that specifies a monitor to start,
> delete it. Next I'd look at the monitorcap file that should be in
> $GISBASE/etc/.
> See if you have one. If you do, look at it with a text editor. It should have
> one line for each potential display monitor it can open. There should not be
> any duplicates. I've had duplicates show up in a Mac build recently.
> In a strange, unrelated problem (but then again, maybe not), that has affected
> a student in my lab who updated to the newest Cygwin binary. Whenever he
> starts GRASS, it opens a saved workspace file even though he doesn't
> explicitly instruct it to do so.
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
> <http://www.public.asu.edu/%7Ecmbarton>
> From: Vishal Mehta <vishalm1975 at gmail.com>
> Date: Sun, 26 Feb 2006 15:07:43 +0530
> Cc: "Ing.Peter Misovic" <peter.misovic at gmail.com>, Multiple recipients of list
> < GRASSLIST at baylor.edu>
> Hi,
> i've been trying to install GRASS, on my Ubunty Hoary distribution, the GRASS
> distribution Generic GNU/Linux (ia32)
> <http://grass.itc.it/grass61/binary/linux/snapshot/> (generated weekly):
> I downloaded grass6.1.cvs-i686-pc-linux-gnu-25_02_2006
> but am having problems as soon as i 'enter GRASS'. I've tried updating the
> scripts you mention in the last email from your website but still get the same
> error
> On the command window i get:
> Could not execute monitor: No such file or directory
> No socket to connect to for monitor <x3>.
> Problem selecting x3. Will try once more
> and the error log in the GIS Manager is:
> child process exited abnormally
> while executing
> "exec -- d.mon start=x3 >@ stdout 2>@ stderr"
> ("eval" body line 1)
> invoked from within
> "eval exec -- $cmd $args >@ stdout 2>@ stderr"
> (procedure "run" line 2)
> invoked from within
> "run "d.mon start=$mon""
> invoked from within
> "if ![catch {open "|d.mon -L" r} input] {
> while {[gets $input line] >= 0} {
> if {[regexp -nocase "$mon.*not running" $line]} {
> r..."
> (procedure "Dm::displmon" line 3)
> invoked from within
> "Dm::displmon x3"
> invoked from within
> ".mainframe.frame.pw1.f0.frame.rb3 invoke"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w $cmd]"
> (procedure "tk::CheckRadioInvoke" line 3)
> invoked from within
> "tk::CheckRadioInvoke .mainframe.frame.pw1.f0.frame.rb3"
> (command bound to event)
> PLease help!
> vishal
> On 2/26/06, Michael Barton <michael.Sbarton at asu.edu> wrote:
>> The new GIS Manager (gis.m) is in beta testing and I've been fixing bugs
>> regularly.
>> Please update to the most current version (24 February 2006). You can get
>> this by updating from the cvs and recompiling or by getting the package off
>> my website <http://www.public.asu.edu/~cmbarton/files/grass_gismgr>
>> <http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr>
>> ...and replacing the files in $GISBASE/etc/gm with those in the package you
>> download.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> > From: "Ing.Peter Misovic" < peter.misovic at gmail.com
>>> <mailto:peter.misovic at gmail.com> >
>>> > Date: Sun, 26 Feb 2006 01:34:57 +0100
>>> > To: GRASSLIST <GRASSLIST at baylor.edu>
>>> > Subject: [GRASSLIST:10572] GRASS 6.1cvs gis.m error
>>> > Dear all
>>> > I'd like to ask you for help with gis.m Grass manager. Manager is not
>>> > starting properly 'cause it is crashing with following error :
>>> > GRASS 6.1.cvs (spearfish):/ > gis.m
>>> > PNG: GRASS_TRUECOLOR status: TRUE
>>> > PNG: collecting to file: dispmon_1.ppm,
>>> > GRASS_WIDTH=640, GRASS_HEIGHT=482
>>> > Graphics driver [gism] started
>>> > ERROR: PNG: couldn't open output file dispmon_1.ppm
>>> > ERROR eof from graphics driver.
>>> > And if I press Enter in error window, gis.m starts, but no work is
>>> > possible at all. My Grass version is
>>> > grass-6.1.cvs_src_snapshot_2006_02_20 .
>>> > Thank you for your help,
>>> > Peter Misovic
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060226/74fe40f6/attachment.html
