[GRASSLIST:10601] Re: problems with GIS managerRe: GRASS 6.1cvs gis.m error
Vishal Mehta
vishalm1975 at gmail.com
Mon Feb 27 00:32:16 EST 2006
Hi Mike,
After entering grass, i saw that The grassrc6 file did have "MONITOR: X1" -
which i deleted. I also checked the monitorcap file, which did not have
duplicates.
I'm still getting the same errors. copied below is the monitorcap file:
any other suggestions? thanks much for your reply..- vishal
# Monitorcap file: describes the monitors available to your
# users. Fields:
# driver name :
# actual program name :
# short description presented to users :
# the names of two fifo files for interprocess communication :
# full pathname of tty from which device must be started (if any) :
# message user gets if driver is started from wrong tty
x0:driver/XDRIVER:X-windows graphics display: \
dev/fifo.1a dev/fifo.1b \
::any terminal
x1:driver/XDRIVER:X-windows graphics display: \
dev/fifo.2a dev/fifo.2b \
::any terminal
x2:driver/XDRIVER:X-windows graphics display: \
dev/fifo.3a dev/fifo.3b \
::any terminal
x3:driver/XDRIVER:X-windows graphics display: \
dev/fifo.4a dev/fifo.4b \
::any terminal
x4:driver/XDRIVER:X-windows graphics display: \
dev/fifo.5a dev/fifo.5b \
::any terminal
x5:driver/XDRIVER:X-windows graphics display: \
dev/fifo.6a dev/fifo.6b \
::any terminal
x6:driver/XDRIVER:X-windows graphics display: \
dev/fifo.7a dev/fifo.7b \
::any terminal
CELL:driver/CELL:Create GRASS Raster File: \
dev/fifo.8a dev/fifo.8b \
::any terminal
#sunview:driver/SUNVIEW:Sun graphics display: \
# dev/fifo.9a dev/fifo.9b \
# ::any terminal
#4105:driver/4105:Tektronix 4105: \
# dev/fifo.10a dev/fifo.10b \
# ::any terminal
#iris:driver/IRIS:Silicon Graphics IRIS Workstation: \
# dev/fifo.11a dev/fifo.11b \
# ::any terminal
#sun:driver/SUNCORE:Sun Core graphis display: \
# dev/fifo.12a dev/fifo.12b \
# ::any terminal
#IGRAPH:driver/IGRAPH:Intergraph graphics display: \
# dev/fifo.13a dev/fifo.13b \
# ::any terminal
#mass:driver/MASS:Masscomp graphics display: \
# dev/fifo.14a dev/fifo.14b \
# ::any terminal
PNG:driver/PNG:Create PNG Map: \
dev/fifo.16a dev/fifo.16b \
::any terminal
On 2/26/06, Michael Barton <michael.barton at asu.edu> wrote:
> Vishal,
> This is a different issue from what Peter reported. It sounds like there
> is a problem with your installation. I'd start by looking at the .grassrc6
> file in your home directory. If there is a line that specifies a monitor to
> start, delete it. Next I'd look at the monitorcap file that should be in
> $GISBASE/etc/.
> See if you have one. If you do, look at it with a text editor. It should
> have one line for each potential display monitor it can open. There should
> not be any duplicates. I've had duplicates show up in a Mac build recently.
> In a strange, unrelated problem (but then again, maybe not), that has
> affected a student in my lab who updated to the newest Cygwin binary.
> Whenever he starts GRASS, it opens a saved workspace file even though he
> doesn't explicitly instruct it to do so.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton<http://www.public.asu.edu/%7Ecmbarton>
> *From: *Vishal Mehta <vishalm1975 at gmail.com>
> *Date: *Sun, 26 Feb 2006 15:07:43 +0530
> *To: *Michael Barton <michael.barton at asu.edu>
> *Cc: *"Ing.Peter Misovic" <peter.misovic at gmail.com>, Multiple recipients
> of list <GRASSLIST at baylor.edu>
> *Subject: *Re: problems with GIS managerRe: GRASS 6.1cvs gis.m error
> Hi,
> i've been trying to install GRASS, on my Ubunty Hoary distribution, the
> GRASS distribution Generic GNU/Linux (ia32)
> <http://grass.itc.it/grass61/binary/linux/snapshot/><http://grass.itc.it/grass61/binary/linux/snapshot/> (generated weekly):
> I downloaded grass6.1.cvs-i686-pc-linux-gnu-25_02_2006
> but am having problems as soon as i 'enter GRASS'. I've tried updating the
> scripts you mention in the last email from your website but still get the
> same error
> On the command window i get:
> Could not execute monitor: No such file or directory
> No socket to connect to for monitor <x3>.
> Problem selecting x3. Will try once more
> and the error log in the GIS Manager is:
> child process exited abnormally
> while executing
> "exec -- d.mon start=x3 >@ stdout 2>@ stderr"
> ("eval" body line 1)
> invoked from within
> "eval exec -- $cmd $args >@ stdout 2>@ stderr"
> (procedure "run" line 2)
> invoked from within
> "run "d.mon start=$mon""
> invoked from within
> "if ![catch {open "|d.mon -L" r} input] {
> while {[gets $input line] >= 0} {
> if {[regexp -nocase "$mon.*not running" $line]} {
> r..."
> (procedure "Dm::displmon" line 3)
> invoked from within
> "Dm::displmon x3"
> invoked from within
> ".mainframe.frame.pw1.f0.frame.rb3 invoke"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w $cmd]"
> (procedure "tk::CheckRadioInvoke" line 3)
> invoked from within
> "tk::CheckRadioInvoke .mainframe.frame.pw1.f0.frame.rb3"
> (command bound to event)
> PLease help!
> vishal
> On 2/26/06, *Michael Barton* <michael.Sbarton at asu.edu> wrote:
> The new GIS Manager (gis.m) is in beta testing and I've been fixing bugs
> regularly.
> Please update to the most current version (24 February 2006). You can get
> this by updating from the cvs and recompiling or by getting the package
> off
> my website <http://www.public.asu.edu/~cmbarton/files/grass_gismgr><http://www.public.asu.edu/%7Ecmbarton/files/grass_gismgr>
> ...and replacing the files in $GISBASE/etc/gm with those in the package
> you
> download.
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
> > From: "Ing.Peter Misovic" < peter.misovic at gmail.com
> <mailto:peter.misovic at gmail.com> <peter.misovic at gmail.com> >
> > Date: Sun, 26 Feb 2006 01:34:57 +0100
> > To: GRASSLIST <GRASSLIST at baylor.edu>
> > Subject: [GRASSLIST:10572] GRASS 6.1cvs gis.m error
> > Dear all
> > I'd like to ask you for help with gis.m Grass manager. Manager is not
> > starting properly 'cause it is crashing with following error :
> > GRASS 6.1.cvs (spearfish):/ > gis.m
> > PNG: GRASS_TRUECOLOR status: TRUE
> > PNG: collecting to file: dispmon_1.ppm,
> > GRASS_WIDTH=640, GRASS_HEIGHT=482
> > Graphics driver [gism] started
> > ERROR: PNG: couldn't open output file dispmon_1.ppm
> > ERROR eof from graphics driver.
> > And if I press Enter in error window, gis.m starts, but no work is
> > possible at all. My Grass version is
> > grass-6.1.cvs_src_snapshot_2006_02_20 .
> > Thank you for your help,
> > Peter Misovic
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060227/8ff38b78/attachment.html
