[GRASSLIST:9895] Re: Procedure that I followed for installing GRASS mapserver
siddhesh bhatkar sid_grass at yahoo.com
Wed Jan 18 04:37:31 EST 2006
Hello Stephan,
Thank you for suggesting me to use the recent
gdal-version. I will need to use GRASS 6.0 for
that.Will go through  the installation in the wiki[1].
Hope it works out for me too.
Regards
Siddhesh.
--- Stephan Holl <holl at gdf-hannover.de> wrote:
> Hello siddhesh,
> From your listing below I can see that you are using
> quite old
> libraries. I recommend to use a recend gdal-version,
> because the
> grass-driver has improved a lot since then.
> Apparently you have installed gdal twice, once from
> source (step 2) and
> once from RPM (step 5) which results in a
> double-installation. Most
> probably this does not work without problems.
> So try to use recent libraries and follow the (quite
> short)
> This deals with QGIS, but is mainly the same for
> mapserver since
> mapserver users GDAL/OGR to read GRASS-data.
> Hope that helps
> 	Stephan
> [1]
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassQgisGdalOgrPlugin
> On Tue, 17 Jan 2006 23:13:17 -0800 (PST) siddhesh
> bhatkar
> <sid_grass at yahoo.com> wrote:
> > 1. Installed proj-4.4.9
> > 2. Installed gdal-1.1.9
> >     ./configure
> >     make
> >     make install
> > 3. Installed GRASS5.3
> > 4. Installed libgrass5_0-1.0.0-1mdk.i586.rpm
> > 5. Installed libgdal0-1.1.9-2mdk.i586.rpm
> > 6. Installed proj-4.4.9
> > 7. Installed freetype-2.1.4
> > 8. Installed gd-2.0.12
> > 9. Installed libpng-1.2.8
> > 10. Installed gdal-1.1.9 with grass support
> >     (I think am going wrong here)
> >    ./configure --without-python
> > --with-grass53=~$USER/libgrass/gis
> > --with-libz=/usr/local/lib
> --with-png=/usr/local/lib
> >                --with-jpeg=/usr/lib
> > --with-libtiff=internal   --with-geotiff=internal
> >    make
> >    make install
> >    ldconfig
> > 11. cp -f /usr/include/gd.h  /usr/lib/
> > 12. Installed mapserver-4.4.1
> >    ./configure  --with-proj  --with-ogr
> > --with-gdal=/usr/local/bin/gdal-config
> > --with-gd=/usr/lib  --with-png
> >    make
> >    make install
> >    ldconfig
> > troubleshooting
> > mapserv -v
> > MapServer version 4.4.1 OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR
> INPUT=GDAL
> > INPUT=SHAPEFILE
> > gdal-config  --formats
> > gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211
> bsb
> > xpm sdts raw dted mem jdem envisat elas fit vrt
> > usgsdem l1b nitf bmp jpeg2000 gif jpeg png
> > gdal_translate --formats
> > The following format drivers are configured and
> > support output:
> >   VRT: Virtual Raster
> >   GTiff: GeoTIFF
> >   NITF: National Imagery Transmission Format
> >   HFA: Erdas Imagine Images (.img)
> >   ELAS: ELAS
> >   AAIGrid: Arc/Info ASCII Grid
> >   DTED: DTED Elevation Raster
> >   PNG: Portable Network Graphics
> >   JPEG: JPEG JFIF
> >   MEM: In Memory Raster
> >   GIF: Graphics Interchange Format (.gif)
> >   BSB: Maptech BSB Nautical Charts
> >   XPM: X11 PixMap Format
> >   BMP: MS Windows Device Independent Bitmap
> >   PNM: Portable Pixmap Format (netpbm)
> >   ENVI: ENVI .hdr Labelled
> >   PAux: PCI .aux Labelled
> >   MFF: Atlantis MFF Raster
> >   MFF2: Atlantis MFF2 (HKV) Raster
> >   FIT: FIT Image
> > Kindly help
> > Thanking u all
> > Siddhesh,
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam?  Yahoo! Mail has the best spam
> protection around
> > http://mail.yahoo.com
> GDF Hannover - Solutions for spatial data analysis
> and remote sensing
> Hannover Office      -     Mengendamm 16d      -
> D-30177 Hannover
> Internet: www.gdf-hannover.de      -      Email:
> Phone : ++49-(0)511.39088507       -        Fax:
> ++49-(0)511.39088508
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
