[GRASSLIST:9921] Re: Problems when compiling GRASS in an Opteron
    Jaime Carrera
    jaicarrerahdez at yahoo.com
    Thu Jan 19 09:16:33 EST 2006
Well, it seems that GRASS doesn't find gdal... that's why I asked you if you installed it or not.
  When compiling GRASS type the following
  ./configure --with-gdal=/usr/local/bin/gdal-config
  HTH
  Jaime
Kenneth Roy Cabrera Torres <krcabrer at unalmed.edu.co> escribió:  On Thu, 19 Jan 2006 07:29:26 -0600 (CST), Jaime Carrera
 wrote:
> Hi Kenneth,
>  Did you install gdal?
>  Jaime
Of course I did!!
I installed it by compiling from the source.
> Kenneth Cabrera  escribió:  Hi GRASS users:
> Here is the program error when I try to start with the display manager
> command.
> With  the GRASS 6.0.2RC4 there is no compile (after the "make" command)
> errors.
> Welcome to GRASS 6.0.2RC4 (2006)
> GRASS homepage:                          http://grass.itc.it/
> This version running thru:               Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the graphical user interface with: d.m &
> When ready to quit enter:                exit
> GRASS 6.0.2RC4 (etopo2):~ > Error in startup script: ps.map: error while
> loading shared libraries: libgdal.so.1: cannot open shared object file:
> No such file or directory
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 32)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass-6.0.2RC4/etc/dm/d.m.tcl" line 894)
> What  option should I use to compile the gdal library?
> Thank you for your help.
> begin:vcard
> fn:Kenneth  Cabrera
> n:Cabrera;Kenneth
> adr;quoted-printable:;;;Medell=C3=ADn;Antioquia;00000;Colombia
> email;internet:krcabrer at epm.net.co
> tel;cell:315 504 9339
> version:2.1
> end:vcard
> __________________________________________________
> Correo Yahoo!
> Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
> Regístrate ya - http://correo.espanol.yahoo.com/
Universidad Nacional de Colombia
Sede Medellin
Tel 430 9351
Cel 315 504 9339
Correo Yahoo!
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060119/b0398306/attachment.html
