[GRASSLIST:10033] Re: AW: Problem installing GDAL
Huidae Cho grass4u at gmail.com
Sat Jan 28 16:24:39 EST 2006
Since G_asprintf() function is now defined as a macro on some platforms having
asprintf(), test for G_asprintf() in GDAL configure fails.  Open the GDAL
configure script and change all G_asprintf strings to G_version.
Hope it helps.
Huidae Cho
On Fri, Dec 09, 2005 at 10:51:55AM +0100, Maik Trömel wrote:
> I have forgotten to write which versions I'm running:
> proj: 4.4.9
> geos:  2.1.4
> gdal: 1.3.1
> grass: 6.0.1
> gdal-grass: 1.3.1
>  Georg Lösel wrote:
> >Hello Maik,
> >>I have installed grass-6.0.1 and now i want to run "./configure
> >configure for GDAL ! Right?
> Right!
> >>--with-grass='/.../grass-6.0.1/lib/'
> >try --with-grass=/usr/local/grass-6.0.1/
> Same problem. Is it possible that I've got the wrong version of one package?
> >HTH Georg
> Greetings Maik
