[GRASSLIST:10067] ./configure command for Mapserver-4.6.2
Rochelle MIranda r0chelle_miranda at yahoo.com
Tue Jan 31 01:01:38 EST 2006
Hello everyone,
I have successfully installed all the requisite
packages required to be installed prior to the
Mapserver-4.6.2 installation.
Following is the list of packages installed
1. gd-2.0.33.tar.gz
2. proj-4.4.9.tar.gz
3. gdal-1.3.1.tar.gz
4. GRASS 6.0
5. gdal-grass-1.3.1.1.tar.gz
Can anyone suggest me the configure  command to be
used to install mapserver-4.6.2 with GRASS support?
The one i used was,
./configure  --with-proj  --with-ogr
--with-gdal=/usr/local/bin/gdal-config
                --with-gd=/usr/local/lib
--with-png=/usr/local/lib
mapserv -v
MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I get the 500 internal server error when i try to run
the mapserver
Can anyone tell me the procedure to be followed after
all the packages including  the mapserver-4.6.2 are
installed?
so that my mapserver will be up and running in regards
to the location of the html files and the GRASSDATA.
And about linking the htdocs of /usr/local/apache2/
to /var/www/html
Thanking all in advance
Rochelle
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
