[GRASSLIST:10070] Re: ./configure command for Mapserver-4.6.2
Matthew Perry perrygeo at gmail.com
Tue Jan 31 02:43:13 EST 2006
Rochelle,
  First of al, try "gdalinfo --formats" and confirm that GRASS shows
up in the list of supported formats. Additionally you can do "gdalinfo
/location/mapset/cellhd/rastername" to confirm that gdal can read your
grass data.
 If gdal can talk to grass then so can mapserver. It won't show up in
the mapserv -v output since it is supported through gdal. So long as
your /usr/local version of gdal has grass support, then your configure
command should work alright.
 The " 500 internal server error" suggests that the issue is with the
web server  (apache?) and not with mapserver itself. Perhaps you can
try the "shp2img" utility on your mapfile and see if your output image
is correct. This will bypass apache and confirm that mapserver can
render images from GRASS data sources.
 To get it working on the web, we'll probably need more details about
your setup. The first thing to check would be that the web server user
has access to the mapserv binary, that the library paths are set
properly for this user and that you have a temp directory with write
permissions that can be accessed through the web server. You could
then try accessing the mapfile by a URL similar to this:
http://localhost/cgi-bin/mapserv?mode=map&map=/full/path/to/mapfile
The mapserver list might be a better forum for these types of questions.
Hope this helps a bit,
Matt Perry
On 1/30/06, Rochelle MIranda <r0chelle_miranda at yahoo.com> wrote:
> Hello everyone,
> I have successfully installed all the requisite
> packages required to be installed prior to the
> Mapserver-4.6.2 installation.
> Following is the list of packages installed
> 1. gd-2.0.33.tar.gz
> 2. proj-4.4.9.tar.gz
> 3. gdal-1.3.1.tar.gz
> 4. GRASS 6.0
> 5. gdal-grass-1.3.1.1.tar.gz
> Can anyone suggest me the configure  command to be
> used to install mapserver-4.6.2 with GRASS support?
> The one i used was,
> ./configure  --with-proj  --with-ogr
> --with-gdal=/usr/local/bin/gdal-config
>                 --with-gd=/usr/local/lib
> --with-png=/usr/local/lib
> mapserv -v
> MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I get the 500 internal server error when i try to run
> the mapserver
> Can anyone tell me the procedure to be followed after
> all the packages including  the mapserver-4.6.2 are
> installed?
> so that my mapserver will be up and running in regards
> to the location of the html files and the GRASSDATA.
> And about linking the htdocs of /usr/local/apache2/
> to /var/www/html
> Thanking all in advance
> Rochelle
Matt Perry
http://www.perrygeo.net
