[GRASSLIST:10096] Re: adding attributes in txt file to vector
    Dylan Beaudette
    dylan.beaudette at gmail.com
    Tue Jan 31 12:35:09 EST 2006
On Tuesday 31 January 2006 08:29 am, Martin Wegmann wrote:
> hello,
> as far as I remember I asked this question before but forgot the answer and
> did not find the right mails in the mailing list search.
> I have a vector with distinctive cats and a txt/csv file with corresponding
> ones plus attribute data - how to I import and link the txt-attribute file
> to the vector file?
> thanks in advance, Martin
Hi Martin,
what sort of attribute storage system are you using for your vector data? If
you are using SQlite, or any other RDBMS like PGSQL or MySQL you can simply
read the text file into a new table- then perform a join between the two
tables (... where vector.cat = new_table.cat ...). Finally, use v.db.connect
to connect the new table (with labels) to your original vector file. As for
DBF data... that might be a little more complicated. Perhaps dumping the
files to text, and using the UNIX command 'join' ??
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
