[GRASS-user] v.clean oddities
M S
mseibel at gmail.com
Sat Jul 1 19:39:27 EDT 2006
sorry for the repetitive posting about the same issue, but i'm determined to
get this. I have been at this for a week, but think I finally found what i
need to do. hopefully there is a way to automate this effort. i'm not
getting the results i would anticipate.
I whittled my data down to a subset because running v.net.steiner on 28,000
lines with 208 points took 3 days. when i used 2,000 lines and 17 pionts i
was able to get some results quicker and try to figure out whats wrong.
i have points (buildings) and lines (streets). I used v.distance to make
the connecting lines. i used v.category to add categories to the connecting
lines, because all the cats were zero. when i would patch them together
like this, the connectors wound up on on layer 0. not sure if this matters
for network analysis. when i add categories and patch them together, the
lines are on layer 1 and the points are on layer 1. all seems good so far.
v.clean.... i am very familiar with vector data editing and operations in
a/i, but i dont understand the outputs from v.clean. i have used default
values and also specified thresholds. not all the lines get snapped to new
lines from the connectors to the streets. in the last run of 17, 1 line did
not intersect/snap to the streets, even with varying thresholds. i found
that i had to use v.digit to add a verticie and split the line prior to
v.clean (after knowing which lines were not snapping).
Is there a way to automate this? Does v.clean have to have a verticie in
the threshold radius to snap to the street lines? Or can it snap nodes to
lines when a verticie is not in the threshold?
Using v.distance, i would expect the connectors to be exactly at the street
lines. in the event that they are such a fraction of a distance from the
streets, a "1" threshold should get them snapped to the streets. any reason
why it wouldnt? it seems that there has to be a verticie in the threshold
and the man pages illude to this as well
thanks,
Mark
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060701/9951031c/attachment.html
