[GRASS-user] 360 degree view from a given point
Glynn Clements
glynn at gclements.plus.com
Mon Jul 3 11:30:27 EDT 2006
Jachym Cepicky wrote:
> how to force nviz to work in batchprocess even without Xserver to be started?
For a start, you would need an OpenGL implementation which doesn't
require an X server, i.e. Mesa with the OSMesa library.
Apart from that, you might be better off just using the OGSF library
directly. Most of NVIZ is the UI; the OGSF library does all of the
actual rendering.
