[GRASS-user] 360 degree view from a given point
Ludwig Max Brinckmann
ludwigbrinckmann at gmail.com
Mon Jul 3 12:10:41 EDT 2006
> Apart from that, you might be better off just using the OGSF library
> directly. Most of NVIZ is the UI; the OGSF library does all of the
> actual rendering.
I found only http://mpa.itc.it/markus/grass61progman/ogsflib.html. Is there
any more documentation or examples on how to use this library (I guess the
NVIZ code)?
Ludwig
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060703/69505d16/attachment.html
