[GRASS-user] 360 degree view from a given point
Tue Jul 4 15:03:10 EDT 2006
Ludwig Max Brinckmann wrote:
> > Apart from that, you might be better off just using the OGSF library
> > directly. Most of NVIZ is the UI; the OGSF library does all of the
> > actual rendering.
> I found only http://mpa.itc.it/markus/grass61progman/ogsflib.html. Is there
> any more documentation or examples on how to use this library (I guess the
> NVIZ code)?
I'm not aware of any other documentation, or of any examples except
for NVIZ.
