[GRASS-user] xganim Error: attempt to add non-widget child
"DropSiteManager" to parent "xganim" which supports only widgets
Glynn Clements
glynn at gclements.plus.com
Wed Jul 5 03:37:57 EDT 2006
Nagesh Bhatkar wrote:
> I have mandriva 2006 linux OS. After installing lesstif-0.95.0.tar.gz
> (Containing the Xm library) ,
> I installed the xganim module of GRASS 6.0 successfully.
> However i get the following error at run time:
> Warning: XmManager ClassInitialize: XmeTraitSet failed
> Error: attempt to add non-widget child "DropSiteManager" to parent
> Kindly drop in suggestions to fix this error.
Try using Open Motif instead of LessTif.
