[GRASS-user] xganim Error: attempt to add non-widget child "DropSiteManager" to parent "xganim" which supports only widgets
Nagesh Bhatkar bnagesh at nio.org
Wed Jul 5 06:45:38 EDT 2006
Dear Sir,
As u suggested i installed the Open motif package on my system.
Compiled the code xganim successfully.
However i get the following error at run time:
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 19 (X_DeleteProperty)
Resource id in failed request: 0x0
Serial number of failed request: 93
Current serial number in output stream: 97
Kindly help me get rid of this error.
Regards
Nagesh
Glynn Clements wrote:
>Nagesh Bhatkar wrote:
>>I have mandriva 2006 linux OS. After installing  lesstif-0.95.0.tar.gz
>>(Containing the Xm library) ,
>>I installed the xganim module of GRASS 6.0  successfully.
>>Warning: XmManager ClassInitialize: XmeTraitSet failed
>>Kindly drop in suggestions to fix this error.
>Try using Open Motif instead of LessTif.
