[GRASS-user] problem whit raster images
Wolfgang wollez at gmx.net
Wed Jul 5 15:04:05 EDT 2006
usually during input the colors are getting separated into the "red",
"green" and "blue" chanal (you can display these chanals as gray scale
images). For displaying you could use:
  d.rgb red=map.red green=map.green blue=map.blue
An alternative is to merge them first:
  r.composite red=map.red green=map.green blue=map.blue output=map.rgb
  d.rast map.rgb
(replace 'map' with your map name)
the other problem ist probably due to the fact that you need an
X-display, before you can display any maps! So try this:
  d.mon x0
I hope this helps you
Wolfgang
