[GRASS-user] r.in.gdal -f bug?
Hamish
hamish_nospam at yahoo.com
Sun Jul 9 18:16:06 EDT 2006
Wolfgang wrote:
> I'm not sure if this is a bug, but when I try:
> r.in.gdal -f (to list all formats) I get:
> ERROR: Required parameter <input> not set:
> (Raster file to be imported).
> ERROR: Required parameter <output> not set:
> (Name of output raster map).
> I would expect that -f should work without any input and output maps
> given and this should give the same output as gdal_translate --formats
It's a limitation of the parser; you need to give it dummy values:
r.in.gdal -f in=foo out=bar
> PS: would it we possible for the next binary release for cygwin to
> compile gdal with ecw support? I really appreciate that someone
> provides the cygwin installation packages (as I don't know how to
> compile all on my self)!
You'll have to check the ecw software license and beg the package
maintainer directly.
Hamish
