[GRASS-user] Can't start GRASS 6.0.0
RAVI KUMAR ravivundavalli at yahoo.com
Tue Jul 11 06:31:50 EDT 2006
1. GRASS depends on several dependency files.
The error you quote resebles a 'Failed Dependency'.
2. While you installed the dependency files, note the feed back (errors) pl.
Depending on these errors you can narrow down the diagnosis for this melady.
Ravi
Mar�a Piquer Rodr�guez <almecloud at hotmail.com> wrote:
Hello, as a new user... I guess I am getting the common problems... I
intalled GRASS 6.0 because were I work I cannot intall 6.1 ( I cannot unzip
the files of the 6.1) as I am not the complete administrator of my computer.
I started to try with the shearfish data and when I try to ENTER GRASS it
does not start... I get the following error:
GRASS 6.0.0 (shearfish60):~>Error un start up script : child process exited
abno rmally when executing ...
I tried several times and I also tried to start it by using the command "d.m
& ", a screen (with a detail of a map) shows up Loading data, it says Done
but I get the same error again...
Can anyone advice me what to do? Thanks
Mar�a Piquer
_________________________________________________________________
Un amor, una aventura, compa��a para un viaje. Reg�strate gratis en MSN Amor
& Amistad. http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
grassuser mailing list
grassuser at grass.itc.it
http://grass.itc.it/mailman/listinfo/grassuser
Sneak preview the  all-new Yahoo.com. It's not radically different. Just radically better.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060711/969a1ac7/attachment.html
