[GRASS-user] Ubuntu 6.06 Dapper: strange sudo hints printed at
startup
twiens
twiens at interbaun.com
Thu Jul 13 18:19:48 EDT 2006
I don't know why either, but I get the same message on
Dapper too.
T
> Hi,
> When I start Grass 6.1, 5.5 or 6.01 on Ubuntu Dapper I
> receive strange hints about using sudo for some purpose.
> No matter if I start Grass with -gui or -text. I don't
> understand why I would need sudo for anything with Grass.
> Example:
> Welcome to GRASS 6.1.cvs (2006)
> GRASS homepage:
> http://grass.itc.it/
> This version running thru: Bash Shell
> (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> Start the graphical user interface with: gis.m &
> When ready to quit enter: exit
> To run a command as administrator (user "root"), use
> "sudo
> <command>".
> See "man sudo_root" for details.
> "sudo
> <command>".
> those look strange!
> GRASS 6.1.cvs (xy):~ >
> What could it be? I can reproduce this strange behavior on
> other Dapper box, but I never had such thing on previous
> Ubuntu (Breezy) version, though I'm installing Grass the
> same way I used to (building from source,
> --prefix=/usr/local).
> I tried adding 'set -x' debugging flag at the top of
> $GISBASE/etc/Init.sh, but the output still doesn't explain
> why the sudo tip could be printed, here goes few lat lines
> of the output:
> + '[' -f
> /usr/local/grass-6.1.cvs/locale/pl/etc/welcome ']'
> + cat /usr/local/grass-6.1.cvs/etc/welcome
> + echo 'GRASS homepage:
> http://grass.itc.it/'
> GRASS homepage:
> + echo 'This version running thru: Bash
> Shell
> (/bin/bash)'
> (/bin/bash)
> + echo 'Help is available with the command:
> g.manual -i'
> + echo 'See the licence terms with:
> g.version -c'
> + '[' text = text ']'
> + echo 'Start the graphical user interface with: gis.m
> + echo 'When ready to quit enter: exit'
> + case "$sh" in
> + USERHOME=/home/shoofi
> + HOME=/home/grassdata/xy/PERMANENT
> + export HOME
> + bashrc=/home/grassdata/xy/PERMANENT/.bashrc
> + rm -f /home/grassdata/xy/PERMANENT/.bashrc
> + echo 'test -z && . /etc/profile'
> + echo 'test -r ~/.alias && . ~/.alias'
> + echo 'umask 022'
> + echo 'PS1='\''GRASS 6.1.cvs (xy):\w > '\'''
> ++ g.gisenv GISDBASE
> ++ g.gisenv LOCATION_NAME
> ++ g.gisenv MAPSET
> ++ g.gisenv MAPSET
> ++ g.gisenv MAPSET
> ++ g.gisenv MAPSET
> + echo 'PROMPT_COMMAND='\''if test -d
> /home/grassdata/xy/PERMANENT/grid3/G3D_MASK && test
> -f/home/grassdata/xy/PERMANENT/cell/MASK ; then echo
> [Raster and
> Volume MASKs present] ; elif test -f
> [Raster MASK
> present] ; elif test -d
> /home/grassdata/xy/PERMANENT/grid3/G3D_MASK ; then
> echo [Volume
> MASK present] ; fi'\'''
> + '[' -r /home/shoofi/.grass.bashrc ']'
> + echo 'export
> PATH="/usr/local/grass-6.1.cvs/bin:/usr/local/grass-6.1.cv
> s/scripts:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bi
> n:/sbin:/bin:/usr/bin/X11:/usr/games:/home/shoofi/bin/moje
> :/usr/lib/qt3//bin:/home/shoofi/bin/FWTools-linux-1.0.0a7/
> bin_safe:/home/shoofi/bin"'
> + echo 'export HOME="/home/shoofi"'
> + /usr/local/grass-6.1.cvs/etc/run /bin/bash
> "sudo
> <command>".
> "sudo
> <command>".
> Any ideas?
> Maciek
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Trevor Wiens
