[GRASS-user] Importing e00 and running m.in.e00
Shaun Walbridge walbridge at nceas.ucsb.edu
Fri Jul 21 20:49:52 EDT 2006
It should be mentioned that the CVS version of GDAL (OGR specifically)
has native E00 support -- so in the long run, GRASS should probably
phase out v.in.e00 for the more robust driver, v.in.ogr.  Probably not
for a few months yet, till a GDAL release is made, packages are made, et
cetera.
Shaun Walbridge
Hamish wrote:
> Alexandre Leroux wrote:
>>I need import e00 files using Grass 6.0.2. When I look at the importing
>>raster menu, I find nothing. Searching on the Internet made me aware of
>>m.in.e00 (http://grass.itc.it/gdp/html_grass5/html/m.in.e00.html ) but
>>when I try to run it from the command tool, I get this not found error
>>"GRASS-GRID > m.in.e00   /bin/ksh: m.in.e00: not found".
>>GDAL does not support e00 files (http://gdal.org/formats_list.html).
>>I wanted to solve this simple issue myself and I'm sure this topic was
>>discussed on many occasions, but I haven't found a way to search the
>>list's archive (http://grass.itc.it/pipermail/grassuser/). I also took a
>>look at the GRASS wiki without any luck.
> v.in.e00
> http://grass.ibiblio.org/grass61/manuals/html61_user/v.in.e00.html
> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
