[GRASS-user] Disabling gis.m
Glynn Clements
glynn at gclements.plus.com
Tue Jul 25 03:50:20 EDT 2006
Joel Pitt wrote:
> Is there an option somewhere to change the startup GUI to d.m?
> I dislike having three new windows pop up everytime I want to run
> grass but still like having a GUI to manage the display. Also all my
> custom tools use x0 monitors.
Start GRASS in text mode to avoid running gis.m; you can start d.m
from ~/.grass.bashrc.
> Also another question: Does gis.m use a seperate viewing region that
> is different from the working region which modules use?
gis.m uses a separate region for display commands and the
georectifier. AFAICT, other commands run from the menus should use the
normal region (although it's debatable whether this is a good idea).
