[GRASS-user] how to add categories to vector created with r.to.vect
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Jul 27 11:08:31 EDT 2006
I created the vector file (lines) with  r.to.vect
In help I red that NO CATEGORIES for lines are created (I understood -
the obiect hasn't identifier). I need to work on data base with them so
I need give them a cat values
The manual entry is not an option because there is over 32000 lines
any ideas?
I can't still use PostGIS due to problems with installation (if somebody
will sugest it)
Jarek
