[GRASS-user] how to add categories to vector created with
r.to.vect
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Jul 27 11:22:24 EDT 2006
Jarek Jasiewicz napisał(a):
> I created the vector file (lines) with r.to.vect
> In help I red that NO CATEGORIES for lines are created (I understood -
> the obiect hasn't identifier). I need to work on data base with them
> so I need give them a cat values
> The manual entry is not an option because there is over 32000 lines
> any ideas?
> I can't still use PostGIS due to problems with installation (if
> somebody will sugest it)
> Jarek
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
I solved it using v.category.
Sorry for fuss
Jarek
