[GRASS-user] GRASS & PostgreSQL - simplist workings
M S
mseibel at gmail.com
Fri Jul 28 07:28:09 EDT 2006
what is the simplest way to get GRASS connected to a PostgreSQL database? I
have built a postgres database and created a table.
I suspect that i have two problems:
1) my pg_hba.conf file (or not starting postmaster with -i flag? it is
currently started from an init.d script, but i thought i located where in
that startup script file postmaster is fired up and have tried -i)
2) my command line connection may be faulty.
my pg_hba.conf file for host has "host all all 192.168.0.0/16 trust"
my connection attempt via GRASS is: v.db.connect -o map=sites driver=pg
database="host=localhost,dbname=sites" table=distances
which yeilds the following error:
DBMI-Postgres driver error:
Cannot connect to Postgres: FATAL: missing or erroneous pg_hba.conf file.
i have also tried using the db.login command too.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060728/62ba49e4/attachment.html
