[GRASS-user] GRASS & PostgreSQL - simplist workings
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Jul 28 16:18:07 EDT 2006
On Friday 28 July 2006 04:28, M S wrote:
> what is the simplest way to get GRASS connected to a PostgreSQL database?
> I have built a postgres database and created a table.
> I suspect that i have two problems:
> 1) my pg_hba.conf file (or not starting postmaster with -i flag? it is
> currently started from an init.d script, but i thought i located where in
> that startup script file postmaster is fired up and have tried -i)
> 2) my command line connection may be faulty.
> my pg_hba.conf file for host has "host all all 192.168.0.0/16 trust"
> my connection attempt via GRASS is: v.db.connect -o map=sites driver=pg
> database="host=localhost,dbname=sites" table=distances
> which yeilds the following error:
> DBMI-Postgres driver error:
> Cannot connect to Postgres: FATAL: missing or erroneous pg_hba.conf file.
> i have also tried using the db.login command too.
have a look at these links:
http://www.postgresql.org/docs/8.1/interactive/client-authentication.html
http://www.postgresql.org/docs/8.1/interactive/libpq-envars.html
http://www.postgresql.org/docs/8.1/interactive/libpq-pgpass.html
c/o postgis mailing list.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
