[GRASS-user] r.in.gdal and .ecw files
Aaron Racicot
aaronr at ecotrust.org
Mon Jul 31 17:43:29 EDT 2006
Your version of gdal needs to be built against the ECW SDK from
ermapper. Someone else who supports the binary packages will have to
tell you how to get a version with the correct build, but if you are
building yourself you can just:
1) Download and install the SDK from ermapper
(http://www.ermapper.com/downloads/sdks.aspx#16)
2) Build gdal with the correct config option (--with-ecw)
Hope that helps...
Aaron
| Aaron Racicot | aaronr at ecotrust.org |
| GIS Programmer | 503.467.0759 |
| e c o t r u s t |
| Jean Vollum Natural Capital Center |
| 721 NW Ninth Avenue |
| Suite 200 |
| Portland, OR 97209 |
| www.ecotrust.org |
-----Original Message-----
[mailto:grassuser-bounces at grass.itc.it] On Behalf Of Kirk R. Wythers
Sent: Monday, July 31, 2006 2:33 PM
To: grassuser at grass.itc.it
Subject: [GRASS-user] r.in.gdal and .ecw files
Does anyone know if r.in.gdal reads .ecw files? According to the docs it
does (http://www.gdal.org/formats_list.html). However, I am getting a
"not recognised as a supported file format" error. If I use the -f (list
supported files option) with r.in.gdal, ecw is not listed.
Thanks,
Kirk
Kirk R. Wythers, Research Fellow
Dept. of Forest Resources
University of Minnesota
1530 Cleveland Ave N
Saint Paul, MN 55108
tel: 612.625.2261
email: kwythers at umn.edu
