[GRASS-user] r.in.gdal and .ecw files
Kirk R. Wythers
kwythers at umn.edu
Mon Jul 31 17:47:33 EDT 2006
On Jul 31, 2006, at 4:43 PM, Aaron Racicot wrote:
> Your version of gdal needs to be built against the ECW SDK from
> ermapper. Someone else who supports the binary packages will have to
> tell you how to get a version with the correct build, but if you are
> building yourself you can just:
> 1) Download and install the SDK from ermapper
> (http://www.ermapper.com/downloads/sdks.aspx#16)
> 2) Build gdal with the correct config option (--with-ecw)
> Hope that helps...
Thanks Aaron. I just re-ran my gdal config script and see saw that
you are correct:
ECW support: no
I also see that the free version will only read files up to 500
megs... what a bother.
> Aaron
> | Aaron Racicot | aaronr at ecotrust.org |
> | GIS Programmer | 503.467.0759 |
> | e c o t r u s t |
> | Jean Vollum Natural Capital Center |
> | 721 NW Ninth Avenue |
> | Suite 200 |
> | Portland, OR 97209 |
> | www.ecotrust.org |
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> [mailto:grassuser-bounces at grass.itc.it] On Behalf Of Kirk R. Wythers
> Sent: Monday, July 31, 2006 2:33 PM
> To: grassuser at grass.itc.it
> Subject: [GRASS-user] r.in.gdal and .ecw files
> Does anyone know if r.in.gdal reads .ecw files? According to the
> docs it
> does (http://www.gdal.org/formats_list.html). However, I am getting a
> "not recognised as a supported file format" error. If I use the -f
> (list
> supported files option) with r.in.gdal, ecw is not listed.
> Thanks,
> Kirk
> Kirk R. Wythers, Research Fellow
> Dept. of Forest Resources
> University of Minnesota
> 1530 Cleveland Ave N
> Saint Paul, MN 55108
> tel: 612.625.2261
> email: kwythers at umn.edu
